Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Sun Jun 15, 2008 12:56 pm
As far as filters, an AEM Dryflow is all I use. I am not a fan of having to oil and all that crap. The Dryflow also flows more air, and filters out finer particles that an oiled filter.
On an 01 Maxima, the silicone sleeve that connects to the TB would need to be a 2.5".
Hardest part about fabbing your own intake for the Max, is the MAF connector plate.
I would recommend a short ram intake, since a true CAI is a lot of tubing, and will lower your throttle response. A short ram will give you better throttle response, and is much less of a PITA to install, and change filters on.
FWIW, look on Ebay and craigslist, and see if you can find a used Frankencar intake. Should cost you about $30-$50 used, IF you can find one. Also, if you find one, buy it asap. It won't be there tomorrow, if you wait. They're not so easy to find, plus fitment and sound, are awesome.
