EazyBreazy »
https://forums.nicoclub.com/eazybreazy-u10672.html
Wed Nov 29, 2006 8:11 pm
First off, if you want suspension advice you should post it in the suspension forum. But since i'm here I'll help a little.
Coilovers are a good place to start, but when you lower your car, it will gain camber. This gain in camber will cause a gain in toe. Camber is your friend (to an extent), but toe that is out of factory specs will cause tires to wear quickly.
When you lower your car ensure you take it to get an alignment imediately. Doing this will not only save you money, but it will also give you a base alignment to start with allowing you to change settings in your alignment at a later date to suit your driving style and so on.
If your car cannot be aligned close factory specs, there are two things you can do.
1) raise the car up, reducing some of the camber and toe gained by dropping it
or
2) Install rear upper camber arms and rear toe links to allow more adjustablility at an extremely low ride height
I may have missed some stuff so be sure to read in the suspension forum and search the rest of the internet so that you can make a more educated decision. Plus, the more you know about something the more likely you are to be able to diagnose what it is doing
