I need suspension advice!
Big Tone
Car: 1993 Infiniti J30
I need advice on whether or not I should upgrade the suspension on the car. Since getting the 18s, the car obviously rides a little rougher than before. Can anyone tell me what shocks/struts are good? I don't know what they cost so I don't really know what price range other than I don't need the most expensive/ top of the line, but would rather not go for the cheapest, either. A moderately-priced shock/ strut will work.
The car doesn't always ride rough, but I do notice it at around 50 and again just over 60.
yodawill2000
Car: 94 Infiniti J30
Only have one choice my friend ..OEM ..Unless you do alot of modifications .
487.50 for front and rear struts from Joe .That doesnt include the rubber . Or installation .
Major Ouch !
Big Tone
Ok. I have another question for you. My car is 13 years old, but I only have 53k miles. Is it time for new shocks and struts?
yodawill2000
fuzzycats.com has a link about them ..Mine havent leaked any fluid but the rubber is definetley gone .. Bumpers and such These arent spring chickens we are driving !!
Big Tone
I just went to fuzzycats.com and only saw a DIY about struts. Can you post the link you're referring to?
yodawill2000
Thats all he has ..Just explains the signs of a strut needing replaced .
Big Tone
Gotcha. Thanks! I need to have a couple things looked at before I get too crazy with interior mods. I've been hearing somewhat of a knocking noise when pulling into my driveway. I don't know if it's a ball joint, tie rod end, or what.
yodawill2000
If you hear it going over a bump or even when you hit the brakes firmly it may be a tension rod bushing blown .Mine sounded like a hammer smacking the suspension .EASY to replace the tension rod .
driverdriver
Car: NICO's longtime resident Canuck!!!
Someone once told me larger rims on a stock suspension lead to the suspension wearing out faster. Don't know if this is true?
I guess the point is moot if you your suspension bits are alrady worn out prior to mounting large rims.
