I need Super HELP!
drz1ll3st
Car: 91 s13 abs vlsd hicas daily!
im to the point of pulling out my own hair.. heres my situation, and YES I SEARCHED AND SEARCHED AND SEARCHED!!
i swapped in a 91 ka motor and trans to my 91 s13 hatch. i had all the wiring, and i mean ALL the wiring, checked out by myself. no cuts or anything.
i connected all the connectors to their appropriate places, grounds to the grounds, etc. im getting no spark. i was getting code 21, and i did the diagnostic from the fsm, and got to the point where i had to check the resistor/ condensor, and i am getting nooo power or ground from it, and this is before the resistor is hooked up. i checked alllll fuses and replaced relays with my other perfectly working s13, and still nothing. idk what to do or anything.
the car cranks and im getting fuel, but no spark whatsoever. today, when i went to go check it out, i did nothing to it, meaning changing connections or anything. i simply stopped last night and left off with everything still "not working" and ONLY code 21. today i connected everything back up, maf dizzy ignitor blahblah, and when i went to go crank the car, i saw smoke coming from the ground wire that connects to the dizzy. it only did it when i was cranking the car. i tried it again, and thats when i noticed it was only during crank. i checked the ecu for codes and then i got code 11, 12, 13, 21, 34. WTF!!!???!!! im guessing because of the ground.. i have nooo clue what to do. i need this car asap.
if anybody can help or come check in person, i am in North Jersey, i would GREATLY apreciate it!
idk if this makes any difference, but my instrument cluster does not show the clock, not sure if radio works bc theres none in there at the time, and when i put it on the ON position, only the gas light comes on, and nothing else. everything is connected accordingly, unless im missing something secretly.
PLEASE help me out!!
the only codes i got now are 11, 12, 13, 21, 34... which is probably having to do something with that ground.
i popped open the ecu and saw nothing obviously burnt nor weird.
pepesilvia
Car: 96 S14
where in north jersey are you located? i doubt i'll be able to help, but a second eye on the subject couldnt hurt...
drz1ll3st
Im five minutes away from the giants stadium. I'm going to try switching out ignition switch to see if that does anything. If not i think it's my ecu.. Fml
drz1ll3st
Nobody has an idea of what it could be?
drz1ll3st
i just tested out my distributor.
first plug im not getting a reading, (fluctuating between 0-5v)
second plug i am.
now, would it be possible for me to have a short? where would i test this out? my harness does not seem to have cuts or damages to cause a short. i can get a dizzy from my job (NAPA) but i wanna make sure its that before i fork out $170 with no returns allowed..
thanks!!
PS ANY ANSWER COULD HELP!
PapaSmurf2k3
Site Admin
Smoke coming from the dizzy is never good. I'd first check your electrical connections for corrosion or bent terminals or something, then maybe put a multi meter on them to verify they are giving the correct signal during cranking (not sure what the correct signal would be).
Its very possible you have to replace your distributor.
L3aN-s13
Car: S13 coupe
Seen your other post. ill be doing this tmr. Ill let you know if I find something myself.
