i need sum answers!!
s14a
Car: 98 240 white
ok ive been looking into buying a hotshot header for my auto 98 240sx se. i still havent found a clear answer on sum questions i have. will my ecu throw a code?? i live in cali, will i pass smog??ive heard that there are 2 cats, and i have also heard that there is only one cat and the other is a "dummy." wood i have to buy a cat??. ne help is appreciated.
C-Kwik
If all the smog device connections are in tact on the header, then it probably won't throw any codes.
Technically, you should not pass the visual part of smog. AFAIK, hotshot doesn't look to get CARB EO#'s on their headers. You'll probably pass the chemical part though, as long as you replace the cat(see below), but I can't be certain as I have not seen tests done.
You only have one cat. It's just below the factory exhaust manifold. Underneath the car, there is a section that looks like a cat, but it is not. The hotshot header goes all the way down to this point. A cat made for an S13 will bolt right up in this dummy cat's place.
SilviaS14KA24DE
Car: Doriftu
greddy makes carb exempt headers. i dun know if they make them for our cars though.
Wow, two cats? lol not stock, but with modifications, of course you can put two cats. It won't help exhaust flow, but i'm sure you'll pass emissions if they let you have two cats LOL
marshun
350z's have 4 cats. :P
i dont have any cats. i dont like'em. i like dogs.
silkk
Car: 94 B13
89 S13
07 S2000
350z's has 4 cats?? :eek:
SilviaS14KA24DE
Car: Doriftu
whoa, are you sure it's not those small resonators that look like a small cat?
s14a
Car: 98 240 white
so wood i pass smog in cali???there has 2 b sum1 on this board wit the headers in cali
HaveBlue
Car: 1990 Auto 240sx Hatch
no, you will not pass smog in cali.
And write like a normal person ok?
s14a
Car: 98 240 white
im 2 lazy to type out everything, its easier 2 use shorthandso no smog wit headers in cali?
HaveBlue
wow, thats lazy.No, no smog with headers in cali.
