i need sr20 basic tune-up guide please!!!!!
blackieblack
Car: 240sx s13
ive been looking for hours on a basic tune up guide for the sr. ive done tuneups before but i would like to have a print out for resource and to fall back on. ive checked 240sx.org and general google and yahoo searches and couldnt find anything. can someone point me in the right direction. .
Luke
Hmmm, tune-up is such a general term. That's a term which I believe shops use to rape customers for everything they got. This is irrelevant though since you're doing it yourself. Let me try to answer the best I can:
-Spark Plugs, gapped to .28 to .30 generally-Fuel Filter, inspect fuel lines-Clean MAFS with something like electrical contact cleaner, some use carb/brake cleaner but i don't trust that on my MAFS.-Check things like timing, TPS voltage and idle speed if it's off.-Change oil (duh)-Flush and fill coolant-Replace transmission gear oil, though this is something that doesn't have to happen often-Clean the throttle body opening with carb cleaner-Replace coolant temp sensor, not too expensive (get the two wire ECU coolant temp sensor for the 2.0 SE-R)
I can't think of more right now but if i do i'll add it.
Morph
Car: 91 Sr Powered Coupe
I think that the only thing you forgot was the belts.
Luke
Morph wrote:I think that the only thing you forgot was the belts.
Good one. Check for proper tension and cracking on those too!
If you're really getting into it you can also:
-Bleed the clutch hydraulics, remove the damper loop if you haven't already:http://www.zeroyon.com/index/content/vi ... 7/-Replace the front main crank seal, the rear main is behind the flywheel and isn't an easy thing to replace unless you're working on your clutch.
Morph
ya bleed your clutch for sure i thought that mine was fine but then the guys at xat beld it for me....woah was i wrong it felt 10000 times better after it was blead.
Luke
Btw, you're welcome.
Morph
Luke wrote:Btw, you're welcome.
HAHAHAHA no love for you.
Luke
Btw, Morph, I love the Grayfox/Ninja avatar. GrayFox has been my internet handle since I was 15. (now 23)
blackieblack
Car: 240sx s13
so its pretty straight forward with the sr? nothing that s specific to the engine that im might look over. thank u , thank u.
Morph
Luke wrote:Btw, Morph, I love the Grayfox/Ninja avatar. GrayFox has been my internet handle since I was 15. (now 23)
Yep the guy was imho the best character in the gamd and you didnt even get to play him. Sucks 2 b/c that kitana would have owned.
Luke
blackieblack, yeah it's pretty simple. There are other little things you can check and replace if necessary. Like knock sensor, clean IACV, but that's getting into more work than just tune-up.
Morph wrote:Yep the guy was imho the best character in the gamd and you didnt even get to play him. Sucks 2 b/c that kitana would have owned.
Morph, you actually did get to play as him. I forget what later version it was, but I think it was either the MGS:Source on Gamecube or maybe the VR missions game. I actually chose the name from the original Metal Gear though, way back in the Nintendo days.
Morph
Ya i was talking about MGS for Ps1. I never got a chance to play MGS for NES all i remember playing was the origonal contra that was bad ***.
blackieblack
Car: 240sx s13
yah vr missions you get to play ninja. i hope he comes back in mgs5. i dont care if he was squashed. they can bring him back somehow. jack is a ninja now i guess. he looks kinda like shinobi. anyway thank you sr guru's. it will help.
blackieblack
Car: 240sx s13
