austins240 wrote:no vacuum? how does it run at all? none what so ever?
did you hook up your boost gauge to a bad source?
did you do a leak test?
do your brakes work?
there is vacuum when i give it gas, but my boost gauge is reading almost nothing at idle, gauge is sourced off the of FPR vac line, didnt do a leak down, dont have the tools for it, but i have a friend coming over tonight to do a compression test for me
the converted wrote:Bad cam timing can cause problems like this. A vac leak that bad would have it idling pretty high.
yeah the idle is not high at all, i'll pull the valve cover off and double check to make sure i have the cam timing correctly, it's possible i might have mis-aligned the timing marks when installing the chain, i'll let you guys know the cam timing marks are supposed to be at about 10 and 12 right? and the lobes on the first cylinder are supposed to be facing away from each other right? all while set to TDC
