I need some advice on my build... It's a S1 Rb25/s13 hybrid. After months and months of wiring harness problems, thanks to Suspicious Garage, I finally got most of the kinks worked out. Anyway, I went to have it tuned here in Phx to see what kind of numbers came up and we maxed out around 280 hp on a Mustang Dyno, which is very disappointing considering what I have done to the motor.
Stock Internals
Freddy Intake
Q45 Throttle Body
3 in FMIC
China Top Mount Mani
Big Holset WH1C
Jecs 650 cc Injectors
8 Bit Z32 ECU with Nistune (to control the VTC)
Knock-off 38 mm Wastegate
Knock-off RS BOV
The two biggest problems that I am trying to address right now are:
1. Boost Creep - Just to get my car to the tuner I had my boost turned down to about 8 psi. We left that alone while he adjusted other things in Nistune. Once we were able to wrap the motor up to about 6k the boost just wanted to take off went all the way up to 19 psi. Now I know the wastegate positing in the egay manifolds aren't exactly "favorable" but I was wondering if their is anything else I can do? I am running a screamer pipe setup. Now in theory if I ran the pipe back into the exhaust, wouldn't the natural vacuum in the exhaust pull those gases out faster? Also, with a turbo that large it wants to spool, the tuner didn't want to turn the boost up he though it would over-boost to like 30+. Now my question is if I turned it up slowly and watched what happens at high rpms do you think I would reach a balanced equilibrium or would it want to continue to creep?
2.No VCT - One of the things I noticed on the dyno after we did a couple of runs with the VCT turned off and on is that their was no difference in the results. No clicking of the solenoid...nothing. I know the VCT is based off the speed in the rb's. My speedo isn't working in my s13 but Nistune is reading a speed signal in the consult gauges and the red VCT flag is also coming on. I tested the wires on the backside of the plug and I am getting a hot and ground. I even hooked a jumper from the batt and grounded the other pin, still nothing. No clicking, no change in my idle. Is their any other test I can do to know for sure that my solenoid is dead? Is their any USDM Nissan's that use the same solenoid? Does a SR solenoid work?
The Wastegate
[url=http://www.flickr.com/photos/115987503@N07/12231381434/]
2013-04-01_19-20-07_673
The Dyno
20140130_213802
Dyno pull
https://www.dropbox.com/s/wfbh7xdffdo5g ... 121348.mp4
