I NEED some stuff.
mikerbike
Okay guys, I got my CA running in my S13 on Friday (Feb 15). I have already pulled the engine back out of the car once, and taken the turbo off once. It just so happens that I'm not a total sissy so I'm not giving up yet. I still need parts. If anybody has these or knows where to find them, please let me know.
2. CA MAF
4. CA dipstick
Here's why..
2. I'm using the KA MAF for now.
4. Didn't get it with the motorset. I used the KA dipstick, but it says I'm 7 quarts over filled.
Modified by mikerbike at 9:40 PM 2/17/2008
Modified by mikerbike at 9:25 PM 2/19/2008
Modified by mikerbike at 9:26 PM 2/19/2008
mikerbike
Here's my CA history..
I got the motorset for $300. The engine has been rebuilt. When I got it, the head still needed to be torqued and the manifolds were off. The exhaust manifold, water pump, and clutch had been parted out. A new water pump was included but it isn't the one that centers the pulley correctly.
I got the engine together and bought the missing parts. Got it installed and did all the wiring as per this: http://www.frsport.com/SR20DET....htmlI took the KA MAF plug and connected it right beside the CA Plug so I could use my MAF now and the CA maf would be simple to install when the time comes.
It started quickly and idled *okay*. It was pretty much pouring oil out the side of the oil pump so I turned it off. I took off the alternator and found where it was coming from. It looks like the oil pump gasket had been cracked apart (and probably broken) and then put back on. Needless to say, I was pretty steamed. The next day I pulled the pump off and replaced the gasket, then realized I wouldn't be able to reseal the oil pan without taking it off so I pulled the engine out and put the oil pan back on. I put it back in and started it.
It still idled the same. Then it just died. Just died. Died. I took off the CAS and the little alignment jig thingy wasn't on it anymore. I pulled it out, took it apart and modified it to work again.
Still idles half-crappy. Finally got to take it for a drive. It seems to me like the MAF or TPS is wired backwards or something. After the drive, it wouldnt' even idle without the CAS all the way advanced. If I take it to what seems to be around 4000 (I don't have a tach) it runs perfect til about 75% or so throttle. Anywhere below that, I have to baby it to even get moving. Full throttle, just hiccups and after-fires and possibly backfires (sounds like compressor surge.)
I installed my narrow-band A/F gauge left over from my KA-T and it said it ran lean when it did this hiccup stuff. I thought it might need more fuel since the KA MAF has a different map. i put in some DSM 450cc injectors to see if maybe... Didn't change anything.
After a while, there developed an exhaust leak between the turbo and outlet elbow. I looked in and saw that the gaskets had pretty much burned up and the bolts fell out. (this is after about 5 miles of 'experimental' driving.) I tried to tighten the top bolt and it stripped. Luckily, I bought an extra turbo.
I took off my turbo and manifold and swapped. Sometime while the Earl's feed line was sitting next to me on the ground, I must have stepped on it or kicked it or something and it had a kink. I gently bent it straight again and put everything back together. It still ran the same but now it was dripping oil out of the line.
I'm pretty flustered at this engine. I know I did some stuff wrong (adjusted timing without a timing light, bigger injectors without management etc...) but I feel like I did all of it for a good reason. I've been lurking the forum for a few weeks and have learned quite a bit, but I still need help.
mikerbike
Recap:
When I start out in first gear, it revs away from idle slowly and as soon as there's a load, it seems like when I push the throttle any more than 10%, it bogs, sputters, kicks, backfires, and generally pisses me off. If I can get it up to around 4000rpm (again, i have no tach so this is not exact) it seems to run fine at partial throttle but seems to die off after about 75% throttle.
I HAVE checked, rechecked, double checked and checked again the cam timing.
I have NOT set the CAS to make 15* base timing at idle. It won't idle and will barely run if I back it off any more than completely advanced.
Anyone know what voltage I should see and from which wire/wires on the TPS at WOT/closed?
I'm out of ideas.
Thanks.
mikerbike
It just kept running better and better the farther I advanced it. The plug and wires are what's stopping me from going any farther.
NissanTouge87
Car: 1992 CA18 S13 hatch, 1992 pignose nissan pickup
I have a CAS i can sell ya for 50 bucks plus shipping, if you still want it, i got it on the car and it works and nothing is broke
lemme know
ALSO, check to see what kind of injectors you have..when i bought my engine, i thought it was all oem, and it would buck, hesitate, die and not run right and fould the plugs every 2nd or 3rd crank, turns out i had GTR 444cc injectors in it when they gave it to me and the company didnt tell me, so double check injectors too
Stock injectors are 370cc, try putting autotragic DSM injectors in, they are 390s
mikerbike
I just BARELY bought one from Ebay. I'll PM you if, for some reason, this one doesn't work.
float_6969
It's not uncommon for that internal spline on the exhaust came to slip. You MAY need a new exhaust cam. OR the timing belt may have jumped as well. Have you replaced the timing belt?
mikerbike
Yeah, it's a new timing belt. I have now set the cam timing 3 times. I took it apart again yesterday to make sure the cam gears weren't swapped sides. As far as I could tell, they are the same.
I'll go look for an exhaust cam. Thanks.
float_6969
You might re-set the timing, just in case. It's possible it jumped a tooth and that would cause your problem
