I need some measurements on the KA24 engine and transmission.
themadscientist
I need to know a couple of measurements please.
transmission total length, from engine mating surface to tailshaft.
distance from engine mating surface to centerpoint of the shifter.
distance from engine mating surface to crossmember studs on busshing.
motor mount position, from transmission mating surface to plane of mounting studs.
motor mount spread across from stud to stud.
engine height from motor mount to topmost point.
engine maximum width, the span of the widest of the engine wherever it is.
best guess at the weight of the engine and transmission combo.
250sx
I have none of that info but what you transplanting the motor iinto?
themadscientist
yanking it out.
