mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Wed Sep 23, 2009 6:01 pm
Well, I got one o2 sensor out on the driver side after working on it for about 30 minutes. I spent around 2 1/2 hours on the other before calling it a night. I ended up putting the other sensor back in that I took out so the car can still be driven. I bought a pair of Bosch universal o2 sensors from Autozone which I'm glad I didn't use. The reason is because according to the fold-up manual, there is a white, black, and a gray wire on the universal o2 sensor when actually there are 2 whites and a black. I had a 50/50 chance of getting the two white wires connected correctly. I'm going to try out that website that was posted above and hopefully have a better chance.
I noticed that on my own Q, the left o2 sensor reading is at .030 volts at 2000rpm and the right o2 sensor is at .800volts at 2000rpm. I hadn't been having any of the hesitation and stumbling that the other Q had when they were connected. I decided to disconnect them and I have noticed that I have more throttle response.
