Jesda wrote:
LG's washers and dryers are known to be expensive and troublesome, though pleasant to use while they're working. Dont know anything about their AC units.
What washer and dryer isn't pleasant while working? (open distasteful jokes here).
Back to the a/c thing...
http://www.google.com/products/catalog? ... KYBEPMCMAY#
I have an older model of this style that I bought when it was already a year old. I've had it for 4-5 years and its been nothing by dead nuts reliable. However, knowing what I know now about it here are some things I'd suggest that you keep in mind when purchasing:
- just like your fridge, filter, the fins and coils WILL get dusty. Really dusty. Look for a model where the outside "shell" plastic is easily removed with a few screws. Using 10-15 minutes to disassemble it and using the hose attachment on your vacuum cleaner to clean the dust 1-2x per year will greatly lenghten the life expectency , effectiveness, and performance of your unit.
- Go big or go home. For a portable a/c, get 12,000btus or better. Its not that much of a price difference to not consider it. Plus, its portable! You can move it to the living room if you so desire. Like Joel mentioned, you don't want the thing to blow hardcore for 10 minutes, turn off and then cycle on again 8 minutes later because it reached the thermostat temp. IMO- this pisses me off when I'm awake and even more so when I'm trying to sleep. To much irregular noise.
- Timers. Hopefully your model has a clock and a simple program timer that you can tell it to turn on at 4:30pm to cool the room off before you get home. Remote controls are also neat.
- Ducting. Its cheap and crinkles up the parts that you're not using. This allows you to move your a/c closer to where you are and using less power/fan to keep you cooler than a traditional window unit and lowers your power bill.
- Efficency- I dont notice much of a bump in the power bill with my unit, maybe $15 extra at most.
- Quiet. They're MUCH quieter than a window unit. Remember those older (but not the oldest) units that were in hotel rooms that had that nice gentle hum to help you get to sleep? Mmmmmm, perfect white noise.
- Water collection bucket. Check the size. On hot summer nights I have to get up and empty mine after about 5 hours of running at 64 degrees. When the bucket fills, mine beeps 3x, it gets REALLY hot, and I cant sleep anyway. It becomes automatic and I barely ever remember doing it in the morning. I could just raise the kick-on temp, but I like to keep my room cold enough to hang meat in. Anyway, make sure it is large enough if you don't want to be disturbed.
I'll post pics if you need.
Joel has some excellent suggestions- look for reviews and don't buy blind. Theres nothing worse than a hot day and a craptastic a/c unit.
