I need some help with bolts and questions to finish assembling my motor.
HighwayStar22
Car: 2002 RSX Type-S, 1991 240 Hatch
The CA I got here locally is missing quite a few bolts, mainly up top on the head. If you guys know what type they are, etc I would be eternally grateful.
Valve Cover boltsIntake manifold bolts. (Manifold to Head)Front cover bolts, all of themOil pan.
I think that should do it on what I need. My water pump has a round end to it instead of the square I am used to seeing. Is this the proper water pump or should I be using one with a square end?
Random as well is that I have a #99 auto CA18DET ecu. Is this going ot function properly on my 5 spd motor?
LAST THING I need the spring that goes under the tensioner. Mine is MIA. I guess that got lost too when he gave me the motor. You help is greatly appreciated. I've got the bottom end and top end rebuilt and put back together, just some relativel minor things to button up.
I do appreicate all the help. Everyone here has been a great help. I've come a long way from getting a motor that was almost all the way torn down to getting it rebuilt and reassembled with nice parts. I'm just ready for her to finally run now.
meminto
Car: S13 Silvia CA18DECT
I can get most of that info to you in the next day or two, I have no internet at home at the moment so I am in the occasional net cafe
