Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Dec 17, 2002 3:24 am
Depends on how many thousands of dollars you want to spend?Everything can be made to fit for $10,000. When you add or subtract engine transmission weight you must change the spring rates to balance. Even a V10 or V12 can be made to fit with a total redesign [frame widening]
Obviously just replacing the EXACT engine with a junkyard take out is the least expensive maybe $2,500- 3,000 [including R&R the engine].
Why did you let your engine blow up? What did you do wrong in the build or operation?
