DanielRuff »
https://forums.nicoclub.com/danielruff-u191300.html
Tue Sep 27, 2011 6:18 am
did you get you car running good, again? I am trying to fix a 1989 240sx automatic w air. So far I have had to clean the gas tank, replace the fuel pump, fuel filter, something ate 12 wires in two, and the computer said my engine temp sensor was bad...(code13). Now my computer says code 55 all ok but it idles like crap and has no power at all. It had some noise I couldn't place, so I take the valve cover off and I see half of the timing chain plastic guide (facing the car on the right side) I see half of this laying about half way down the engine, I guess the rest of it is stuck to the pick up tube in the oil pan in pieces. Anyway, what causes that to break and what would cause it to run that bad?? Thanks for any help.
