positron1 »
https://forums.nicoclub.com/positron1-u27022.html
Fri Nov 21, 2008 12:57 pm
I just had to tighten mine so I would suggest that you unplug the coilpack harness and bracket and move those out of the way so you have some room to move back there. Get on the drivers side and push the hose on as far as you can get it then get on the passengers side and use a 7mm wrench to tight the hose fitting or whatever size wrench will fit your hose fitting screws.
