is there a way to check the continuety of the ecu cause i really don't think its getting power-RJ- wrote:i thought the coil was getting power, yeah that sounds about right or you ecu could be shot.
Oops that was some where else i thought i posted it on this one but i didn't.. sorry about that.. but yeah the fuel pupm relay is fine.DubsSuck wrote:you'd think the fuel pump relay would be the first thing i checked.... well it was. and if you would have read the whole thread you would have found out that its fine.
I'll check that other thing you were talking about tho.
pancho y onions wrote:How are ya checking your check engine light? The way to pull off codes is be removing the kickpanle and look at the leds from your ecu flash. Also how postive ar ya its not getting power to the ecu. Just cause the CEL is not on does not mean its not getting power. Also check your IGN switch.
