grullan »
https://forums.nicoclub.com/grullan-u36018.html
Thu Jan 26, 2006 3:22 pm
As per the FSM for a 95 240sx,1> Tighten all bolts in the correct order to 22ft-lbs.2> Tighten all bolts in the correct order to 59ft-lbs.3> Loosen all bolts completely and retighten all bolts in the correct order to 22ft-lbs.4> Tighten all bolts in the correct order to 55-62ft. lbs.
Hope this helps, btw.....there's a sticky for the Factory Service Manual posted on the main forum's page.
Good luck bro.
