Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Tue Jan 11, 2005 4:49 pm
When removing the back seat, to get to the fuel pump, I only found 1 stinkin penny. I was hoping to get enough for a cheeseburger.
After taking out the seat and rear deck, all the panels in the trunk, and the trunk mat, the job was a snap.
By the way, are the little pins that keep the pump from twisting important?
I spent the weekend replacing the driver's window regulator, adjusting the driver's headlight, installing a new trunk closure bumper, putting on my Infiniti vlave stems, replacing the front struts, boots, and upper links on Lola, and replacing the fuel pump, fuel filter, and cleaning the air filter in Layla. It was a good weekend!
By the way, Lola is getting 23 MPG, since I replaced the Bosch plugs with NGK's.
