I need power steering help fast
bigbumpinZ
Car: 1994 300zx LS1 Turbocharged, 1994 300zx NA, 1992 300zx Twin Turbo
i put an underdrive pulley system on my NA Z and i guess i ended up stripping the power steering belt pulley. the bolt that holds it on it pretty stripped and the nut that holds it on is to, is there any way to fix this without buying a whole new pump and pulley
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Wait, are you talking about the tensioning bracket? The tensioning bracket is replaceable, but is a PITA to do nonetheless.
Otherwise, you would be talking about the actual bolt to hold the pulley on, in which case, if you can't get it out with a bolt extractor, you're pretty much boned.
bigbumpinZ
ya its the actual bolt that goes through the pulley and holds it on, it stripped out somehow so now i think i have to buy a whole new pump just because the pulley stripped out the gear piece it holds to :bang
PAintballa45
Car: 1991 300zx n/a (TT in progress : D) slicktop
my buddy did the same thing on his 240, its cheaper to rebuild rather than buy a new one but the main shaft in the pump is messed up
