amolao wrote:zerothread?id=96108
Is kind of late for the pics but here is some info in reference to HUD clusters, Im not really sure what your question is but let me try to help you. The conversion for the analog to digital signal is done at the HUD cluster (where the 2 black connectors are),,,,When you look at the 2 connector in the back of the HUD cluster you have the top for the harness (for speedometer signal coming in) and the smaller bottom one is for the connection for the remote read out (sits under corner front dash) that reflects speed read out on the windshield...When you look at the non HUd cluster is basically direct connections to all signals (speed, warning lights,etc)....Check the FSM for diagrams showing where all signals go and which pins......hope this helps...
Oh also remember that you need the respective harness for the cluster in order to get them to work....you probably know this...
i don't care for the moment about the atualy HUD since i do not have the coupe se dash......but my main question is.....
is the harness all i need for it to plug in the car and makes it work for everything like the indicators for Oil ebrake engien temp fuel and so on.....since lookin at both the clusters all the pins are in different spots so with the SE harness to put in my car will it all go where it should to when it plugs into the ecu? or will my oil light be my ebrake light? you know will things be swapped around and may not even work at all?
i guess its like if i have the wiring harness thats made for that cluster will it all plug up or will i have to get our my wire cutters and start splicing and sodering? bsically is both the ECU the same or both different? no wonder no one really did this mod unless they had a whole front clip i really like that gauge cluster, i think its a perfect design....
thanks for the help so far amolao, yeha after taking it apart i can see the harness is somethign i really needed, buti can get it from the person i got the cluster from since he has no use for it....should have grabbed it then but i had no clue what i needed....
