guyin180 wrote:So what kind of setup should I run coilovers or springs .... I heard ground control springs was ok too? What do you think if I was to get either jic, megan or stance coilover set-up?
If you're serious about drifting... coilovers are the way to go. Don't waste your money on a spring / shock set up.
JIC, Megans, and Stances are all pretty decent choices. Of the 3, JIC wins imho. Second would be Stance, third Megans. Make sure when searching for pricing, that you keep in mind what kind of spring rates you're looking to get. Megans do have an intended "track" coilovers, but they probably wouldn't be ideal for a daily driven car, unless you don't mind a hard ride. Stances (GR+pro I believe) comes with 2 sets of different spring rated springs. A close buddy of mine has the JIC FLT-A2 coilovers. THey're awesome coilovers, but will cost you more than the other two considered coilovers.
