i need new tie rods?
driftfreek
Car: 92 s13
i went to take my s13 for allignment and they told me that i need tie rods. i thought of gettin the stock ones, but then i decided to look into aftermarket ones. i just need some tie rods that are as good as stock or a bit better but at a good price. i found some on the nopi website for the same price as the stock ones from nissan dealer. do you guys have any other ideas or suggestions about this? should i get aftermarket or just keep em stock. i do autocross and road race so..
sean58888
Car: 91 240sx coupe
hey i got some tie rods and tie rod ends for sale IM me at sards14.thanks
86silvia
Car: 86 S12 and 96 S14
peak-performnace tie rods, only $80 bucks for both sides. order from phase2motortrend.com. they work with the stock inners.
180fan
Car: 89 fastback
I'd get aftermarket... I picked up some Kazama inner and outer tie rods at the same time.
driftfreek
Car: 92 s13
whats the difference b/w the inner n outter tie rods??andsince i wanna change my tie rods, do i also need tie rod ends?
Mr HuSTLeR
Car: H2 Hummer, 90 240sx
You don't really NEED to but you should anyways, I like my TEIN tie rods.
180fan
Car: 89 fastback
Outer tie rods - attaches to the knuckle and has the ball joint seal that usually bursts on folks.
inner tie rod - the shaft that rotates around and is attached to the rack.
Change the inner and outer tie rods at once along with the dust boot for the tie rods. It'll save time later on.
