I need new spark plugs....
mmatl16
Car: 240sx rb20 swap
ive got a rb20det and my spark plugs are horrible. I called a local shop and they told me 50 bucks a plug....are there any other plugs that are compatible with the rb engine
Joe
http://www.nissaninfiniticlub....34102
please next time at least look before you post, that is the first thread in this forum.
technorb26
c
mmatl16 wrote:ive got a rb20det and my spark plugs are horrible. I called a local shop and they told me 50 bucks a plug....are there any other plugs that are compatible with the rb engine
Call Mike at Superior Nissan in CA, 626-965-5060
Plugs are $7 each for the NGKs.
mmatl16
sorry kamin....honestly didnt even think about it....i dont usually ask a lot of questions. should have known it would be here.
thanks technor rb26.....do you know where superior nissan is located?
Eikon
Car: 71 240z, 93 Supra TT
http://www.clubplug.net/index.....html
NGK-BCPR5EIX-11
They are $6.50 each plus 6.95 shipping. They also accept paypal which is very convenient.
Project240
They're not hard to find. Hell, I got mine from Pep Boys.
mmatl16
you got rb20 spark plugs at pep boys?
SeVa-S13
Car: '05 GTO 6spd
No, but we got 300ZX spark plugs (I think) at Autozone/Pepboys/Napa or whatever. Companies don't make sparkplugs for the skyline, nissan used a sparkplug that was already in existance for the skyline.
Support your sponsors and save money: http://www.sparkplugs.com/resu...IX-11
Edit: I rock spelling.
Modified by SeVa-S13 at 11:53 PM 1/10/2005
BoostFab
Car: S13cp, S13fb, S14z
$50 each? tell them to go f- themself.
another good one can be use, NGK 3330 (BCPR7ES), coppers, 7 series cold, already gapped at .032", jsut pop them in and boost away. $2.ish each. at Orielly's auto part or any local parts store.
Project240
I'm running 6 series since they're one step colder than the 5, is a 7 series cold plug better if I'm trying to up the boost on the stock motor? It wouldn't be too cold?
BoostFab
Project240 wrote: is a 7 series cold plug better if I'm trying to up the boost on the stock motor? It wouldn't be too cold?
it's better and perfect for high boost.
this supra put down 861 horsepower and 801 ft. lbs. of torque on these ngk 3330 (BCPR7ES) plugs.
Modified by BoostsFed at 12:46 AM 1/11/2005
mmatl16
hey guys i need to get a thermostat too.....before u flame me....dont...i didnt feel like going through endless threads... when u guys just gave such good info so fast....where cn i get one and whats the part number
mmatl16
o and i was told by a shop that my gap is supposed to be .26...is that right what you guys got yours at
Eikon
Z32 turbo thermostat works perfectly... actually I think the N/A works as well. Available at any car parts store for like $10.
I think the NGK's come gapped properly.. I have heard. .08mm not sure what that converts to
mmatl16
thanks for the help guys
accel junky
Geez! $50 bucks a plug! You should hit that guy for just trying to pass that to you!
Bluefire
I Second the BCPR7ES-11, I've used them on two RB25's and will be using them on a third RB25 im swapping now. Plus they're freakin cheap compared to the iridiums
-Bluefire
BoostFab
mmatl16 wrote:o and i was told by a shop that my gap is supposed to be .26...is that right what you guys got yours at
.26" = that's more than 1/4 of an inch....no gap is ever that extreely wide...any motor, period....
on RB motors, stock optimum recommendation for spark plugs gap should be around 0.8mm (metric), that's translate to 0.032" (inch).
mmatl16
sorry meant to type .026
sparkplugs.com
we've got a denso and ngk non-us catalog, it will soon be up on the vehicle lookup on our site, but for now, all i need is the exact make/model/year, and i can tell you their recommendations for all plug types in both brands.
goofynick6
Car: 1995 S14.5 RB20DET
http://filebox.vt.edu/users/nicolasb/DSC00296.JPG
NAPA, $1.95 each or so...and one range colder for larger turbo's or more boost...they're just right
NIck
Carl H
some times the bcpr6es's are hard to find.i get mine from the dealer as i used to work there so i still get mad parts hookups.as for the heat range cooler im not too sure about changing it unless you are running a highly modded engine.im gonna be running the 6's in my car and if i need to i will go to 7's.
goofynick6
5's are stock I believe, so I run 6's, because I run a t3/t04E with 18psi on pump gas...so I wouldn't want to run anything hotter.
Nick
lyon23
Car: 95 240sx
hey nick how fast are you running with that turbo? in the 1/4 or 1/8.
goofynick6
Didn't get to the track yet with it all pieced together, so we'll see this spring.
Nick
