Call them.ErocK wrote:Thanks for the help, i sent a part inquiry to everything nissan, but i couldn't actually find them on any of the sites you suggested.
Thanks again,-Eric
I am planning on using about a 5mm spacer, maybe more but not as much as a 1/2.chmercer wrote:are you planning to use some plate spacers along with your brake swap? im just making sure because if you arent there is no reason to spend any money on studs.
