I need info on swap.
Eastcoast Wildboy
I have a 97 240sx and i wanna put a nissan skyline rb26dett motorswap in it. I need to know do i half to cut anything. My friend said i should make transmission bay bigger and just move radiator forward and that will work. I need some help by someone that knows anyone help?
SunshineAcid
Car: 89 240sx Ka24de swap
im sure youll have to cut something.
Eastcoast Wildboy
waht will need to be cut if so?
SunshineAcid
put in the rb25youll have much less headache. and you wont have to cut metal.
Eastcoast Wildboy
I was thinking about doin that but not near as much hp or as much reliability when hp comes into outlook.
SpeedFreak
McKinney motorsports has a kit for that motor for your car but you will have to cut a longer hole in your shifter area because the transmission is farther back plus you are going to need a custom driveline. The driveline part isnt that bad, any driveline shop can hook you up for a good price. Lots of work but if you wanna really make it ez buy a Simple Digital Systems standalone and then you wont have to deal with wiring much up. A good friend of mine has an Rb26dett in a old 240z with the sds set up. Really easy to use. Anyway I dont know a whole bunch about it but this is stuff that I have heard in the past and if I am wrong....well you know someone will correct me......haters.
Eastcoast Wildboy
How many man hours for cutting do u think and thanks for the info man.
