I need help with vibrations!
xsubxwooferx
Car: nissan 240sx se
car is 1993 Nissan 240sx fastback
When driving, the stick shift shakes constantly if not violently at times and if I go 50MPH or more the steering wheel shakes.I checked under car at the U joints and their fine.
Modified by xsubxwooferx at 2:37 PM 3/10/2008
onosqv
Car: '92 240sx Vert
shift knob shaking usually = bad transmission mount and/or engine mounts. You can look @ your engine mounts - or easily see by popping the hood, start the car, then rev via the throttle cable & see the engine move a lot (it shouldn't move at all).
steering wheel shake usually = bad wheel alignment and/or bad tire balancing/bad tires.
If you searched at all on the forum, you'd find this info as it's been discussed quite a few times...
xsubxwooferx
Well I just put new trans mount on sunday and I tightend the engine mounts today and still does it.
onosqv
Car: '92 240sx Vert
xsubxwooferx wrote:Well I just put new trans mount on sunday and I tightend the engine mounts today and still does it.
Tighten the engine mounts? Have you checked the condition of them? Unless you have some aftermarket engine mounts, you can't really "tighten them down" to make them work better... i.e. did you do the simple test I listed in my post?
xsubxwooferx
yes and when i did that the motor moved sort of just like a normal motor would
onosqv
Car: '92 240sx Vert
Checked your tire balancing? A quick test (if you don't want to pay to have your tires rebalanced) would be to swap the rear rims w/ the front rims. If the shakiness changes, then you know it's the rims.
There are a handful of other things to check, but you should be able to search for those.
00selimited
brokeAs240sx wrote:shift knob shaking usually = bad transmission mount and/or engine mounts. You can look @ your engine mounts - or easily see by popping the hood, start the car, then rev via the throttle cable & see the engine move a lot (it shouldn't move at all).
Agree, id just run a Nismo mount set and be done with it. Also the S13/S14 naturally has more shifter movement then alot of other cars with the fact being that the shifter is directly in the trans and not some sort of linkage system found like on the 300ZX and FWD cars.
480sx
Car: 1996 Pearl White 240sx
JGS over nismo any day of the week.
ELEMENT692121
Car: 93 240 SX SE
your problem could also be in your driveshaft .. you say you checked your u joints how did you do so ??? did you actually unbolt the drive shaft and move them all around ?? your problem sounds identical to the problem i had and it was bad u joints you cant tell there bad till you pull down the driveshaft and move them side to side .. you can thank nissan for making a great designe where u cant replace the ujoints .. i
