i need help with this wiring issue i have with a 91 240sx coupe ka24de
westbank24
Car: 1991 240 sx coupe
so i purchased a 240sx that had some ignition wiring issue.it had a push start installed wrong so i took it out and put a new ignition switch.when i brought it the car wasent turning off (engine and power)even with the key removed so i was stalling it in first gear and disconnect the battery.im trying to find out if there is a specific wire thats responsable for the power in the car not turning off so i can check it and were could it be what color etc..i searched and cant find a wiring digram so if you can give me a link or help me figure out what wire is responsable for the accessories so i can see if they have it jumped of somethingthanks
UPDATEbetter yet what would cause my car from turning off
Modified by westbank24 at 3:18 PM 2/18/2010
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
go to google and search copy and past this:
"240sx FSM NICO"
that should give you a page to where you can get the FSM and find the wiring diagram. Good luck and try and post back with your solution to the problem.
vancouverbc
Car: 1991 240sx
not sure. the "on" wire from ignition switch provides power to ignition coil
Modified by vancouverbc at 11:46 AM 2/19/2010
