I need help with my turbo downpipe!!
fast_s14
Car: 94 300zx
I had posted this before but i had no replies and all you guys wanted more pics so here they are. I have seen a vband set up before but this looks different to me. Here are more pics you guys wanted. Yes that is a SS autochome manifold. I am just using as a template because my uncle owns a machine shop and he is going to make me one that is stronger. Thanks for all the help, you guys rock. It is a T04e turbo with .50ar on the intake and .84 on the exhaust side.
scarboroughdub
what you wanna do depending on the diameter of the inside ring is buy a v band and the v band flanges and have one of them welded onto the turbo itself, then you can attach the other v side of the flange and have a connection, that is the only thing you can do other than to locate a oem piece that went in there.
http://www.burnsstainless.com/....html
C-Kwik
With a little bit of quick research on this, it looks like this is referred to as a slip joint housing. From here, you can add just about any flange you want by using the apporpriate slip joint adapter. This needs to be welded to this type of housing. If you know your turbo trim size, you may be able to simply order a housing with your desired flange alrady welded on. If it were me, I'd go for the V-Band. It's much simpler to work with should you need to ever remove the turbo. Also if you have it welded on, take it to a reputable welder, not just the muffler guy down the street. Welding cast iron takes a lot of time to do as they have to heat the entire piece up, then weld, then bring the temperature of the object down slowly over a period of time(up to 24 hours). If they say anything about using any type of electric welding, walk away. They have no idea what they are doing. Ask the welder about the procedure so you know if understands how to properly weld cast iron. I had to have a cast iron manifold welded once and you would not believe how many welders have no idea how to properly weld cast iron.
