i need help with my head gasket
eddie324
im pretty sure its blown because there is oil mixed in my coolant. and it over heats alot constantly.
is there any good write ups on how to replace head gaskets? with pics would be very helpful
Roger_cha
Car: 91 nissan 240sx
well if you dont know what you are doing then my advice is that you should find some one that has done it or a pro to do it for you. if you get water in the oil pan or oil in the coolant then its defiantly the head gasket. you can search around for the answer.
