I Need Help With my 83 z24!! plz im new!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
ColtonMelson
Car: 1983 datsun 720 z24 2x4 single cab
Hello everyone!! I am so happy that i found this forum! It really made my day. I am NEW to the datsun world. i have always been a VW guy and have read tons of VW forums to build my sandrail. Now i have an 83 datsun and need some help with it.
First, I rebuilt my carb and im still having problems with my idle and have hesitation at low RPM exceleration. SO what i need is instrucion on how to get rid of all the EGR vac line crap and know what i HAVE to keep hooked up to the vac system
Second, I will be buying a weber 38 carb for my truck, any thoughts? should i go for it or no?? also im planning on pace setter headers, anything cheeper out there???
Third, please send me a link instructing me on how to reajust my valves, set my timing with a timing gun, and any other great links you think i would benefit from..
I have read alot of posts you guys have on this forum and i have just not found what im looking for. I can see you guys are really good at what you do and im very open to learn what you take the time to teach
Thank you
Colton :)
Welcome aboard, Colton!
We're still loading the service manuals for the 720 (somehow, we have manuals for everything BUT the 720)... I'll get "The Reverend" or PeZi in here to help, they know the 720's inside and out.
XavierBK
Car: 2011 Yamaha Stryker
1985 Nissan 720
Check the FAQ and DIY threads in this forum. You'll find answers to every question you asked.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
first check for vacuum leaks, there should be vacuum diagrams in the stickies and random info. Also there is a full carb rebuild write up.
The weber pretty much cleans up the vacuum system well. I went to a hydraulics shop and got plugs for the exhaust.
300ZXttZMAN
Welcome to NICO!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
You can remove the VVT valve, the EGR valve and you will need to plug off the middle port on the Thermal Vacuum Valve located on the coolant pipe on the intake side of the cylinder head. Follow the hoses from the VVT valve to the throttle body. Both those lines can be removed and plugged. If I were in your shoes I would look for a Haynes or Chilton manual just to get a glimpse of the vacuum system for reference. I don't have a way of scanning the manual I have. Also note: This info was taken from a 1982 FSM which means the info is for a Z22, there may be slight differences for the Z24. I do not currently own a 1983 FSM yet. You will want to keep the vacuum switch and the boost control unit. You will also want to keep the vacuum advance on the distributor. Go get a Haynes manual so you see the vacuum system pic.
Pacesetters are really the only option out there. I had a Z22 that I put headers on many years ago. The butt dyno said more power but I was a kid back then and couldn't appreciate a car they way I do now.
breadbox
89 Koop
84 720 4x4KC
im-a-dummy-please-assist-me-t465042.html
Vacuum Diagrams are posted in there a couple times, and for all years I do believe.
PEZi
Rev_D21 wrote: Pacesetters are really the only option out there. I had a Z22 that I put headers on many years ago. The butt dyno said more power but I was a kid back then and couldn't appreciate a car they way I do now.
The pacesetters make the truck loud as balls, but only offer about 3-5 whp. Granted, on such a low hp truck, it is still noticeable. There is another brand out there, but the name escapes me. They were good for 5-10 whp but cost about 2-3 times as much. Thorley? Seems to ring a bell.
hablah
Car: datsun 720 dualcab ute x2
i have a 720 datsun manual at home chuck me an email at [email protected] and i can work out how to make it digital so we can all use it
shaunfoldvik
Car: 1982 Datsun 720 King Cab
i was having the same hesitation problem in my 720 and i just got rid of the egr and vvt, and it completely fixed the problem. thanks for the info!
Return to “Datsun 720”
