singlecamhonduhkilla wrote:I WAS TOLD THAT MY ENGINE JUST NEEDED A NEW OILPUMP AND OIL PAN... WELL MY MISSION WAS TO TAKE OFF MY OILPAN YESTERDAY AND I WAS ONLY ABLE TO GET OFF 5-6BOLTS.. THE REST I CANT FIND.. NOR DO I KNOW HOW TO EVEN TAKE IT OFF.. ANY HELP WOULD HELP ME.. OR ANY IDEAS HOW TO TAKE THE PAN OFF SO I CAN GET TO MY OILPUMP.. THANKS A MILLION GUYS!!!JOE
My Question is why do you need a new oil pan? Typically, unless it's damaged enough to somehow block the oil pick-up or it has a hole or something, then there should be no reason to need a new one.
Secondly, IIRC, the oil pump is external on the SOHC. If you follow a straight line from the distributor across the front of the engine, it should be on the other end. The oil pump and distributor use the same shaft.
