I need help wiring my electric fans
dionjrare
Car: 91 SR20 240sx Hatch
Hey fellas, well i got my SR swap done about a month ago and i decided to just wire my electric fans straight to my starter, so i have to unplug the power and plug it back in everytime oi wanna use the car or if not when the car is parked my elctric fans will stay on, well i've noticed now that it takes longer for my car to start n it is starting to kill my battery, what i wanna know is where i should wire up my fans to that way i dont have to unplug my battery evrytime i wanna get outta my car, any help would be great, thanks guys
Oh.....ps if anyone can like foreward me a link err something that'll help me install my walbro 255 fuel pump that would be great to
S14Kouki10
Car: 1997 240sx
rig one of these to it?
dionjrare
Can i leave it still wired up to the starter????
bersh240
the lanc. crew just came over and we redid mine. ill post some pics of it in the morning for you.
its SAFE.
but bassically runs power from battery cable to a relay AND a fuse then to fans. grounded to intake mani.
with a tiny ground going to a switch inside.
ya... ill get pics in the morning.
somebody wana explain it better?
it works perrfecctt.
PyroTecK
Car: 1993 240sx SE 5speed fb
if u add a switch yes... u could turn the fans off when u start the car... or wire in a relay and have it trigger off the fuel pump... mines actually tapped into the fuel pump fuse.
S14Kouki10
Car: 1997 240sx
my brother did it to his old truck. but im pretty sure you can. if you splice the power or ground cable . and you can run wires to the inside and mount the switch somewhere.
dionjrare
Well i was gonna wire it up to the fuel pump but then i was afraid that it wouldn't work as effieciently as it should, but yeah that makes sense to do it that way, umm some diagrams would be nice, or if u can add the pics that would be great
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Using a relay triggered by the fuel pump circuit is one thing but if you're going to just wire into the fuel pump wiring you may as well grow a mullet.
Genpac
Car: '93 240sx RB20DET 'vert
Why not do it right, and still stay fairly inexpensive... look up a hayden 3647 or a 3651. The 3647 has a temp probe that goes into the radiator fins and the 3651 has a 1/8" NPT sending unit that can be screwed into a collar or adapter in the upper rad. hose. It's not fancy but it will do the job properly.
car nut
Car: GT500.
^ I was waiting for someone to suggest that haha. That's similar to what I have on my VH setup (different part but same principal). I have a 2 speed fan so the sending unit turns on the fan on the low setting and then I have a switch on the dash for high speed.
As for your Walbro, it should've come with instructions. All you do is pull the pump and replace the old one with the new pump. Sometimes you need to get a little fancy with mounting it though. 300zx's and 240sx's use the same mounting kit so I wouldn't be surprised if you needed to fab something up too.
s13sickboi
Car: 1997 Nissan Hardbody XE
i did this s*** once with altima fans, switches and relays and s***.... when i noticed my lights dimmed alot i ripped them out and went back to stock for now.... next time (hopefully near future,) im doin it right with one of these... if i can jack someones connector :rotfl
http://www.mishimoto.com/mishimoto-hond ... witch.html
defaultuser89
you can buy a temp probe kit from autozone for pretty cheap it just reads the temp and you can set it to turn the power to the fans on at a preset temp this way you dont have to try to remember to turn the fans on and in the winter when you want that precius heat we all enjoy it wont take longer to heat up cause your fans are always on its real simple to wire just find any hot wire thats on when the cars on or go straight to the battery with a proper amp fuse
dionjrare
Yeah that all sound good, I havent had any time to work on the car yet but when i do i'll keep you guys updated on what i decide to end up doin
