churroboy »
https://forums.nicoclub.com/churroboy-u90995.html
Mon Mar 10, 2008 9:54 pm
"Now run this wire under the dashboard to the driver side foot well. Connect your toggle switch to the two wires. Hide the switch in a creative spot. Start the car with the switch on. It should start and idle normal. Flip the switch off and the idle should start to bog down as the engine starves of fuel. If your switch works correctly, you're done! Bolt your ecm back in and fasten all the interior panels back together. Hide the wires as best you can and the job is complete."
I quoted that from the last step of the tutorial that Hitman created.
Here is my question: If I try to start the engine with my new fuel pump switch off, and the car chokes, etc, will anything bad happen to the engine or will anything mess up? Or if I start the car then turn the switch off? Other than dying out, just wondering if anything will malfuncion? Thanks. The instructions seem pretty simple, I am doing this this weekend!!! But I cant tell where i put my switch!! Heres a good idea though, put is as a button in the radio, so you cant start the car without the radio, and take the radio out when your not parked, or some type of key thing that you can take out when your not in the car. Maybe in the cigarette lighter, by creating a circuit of some sort instead of an actual switch with an obvious button.
