I need help turboing my KA
93240sxS13frontend
Car: 1993 240sx with front end s13 conversion would like to do KAT
hey, i want to turbo my KA, i have 176000 miles on it, with no leaks the motor is clean and the compression is fine. What will i need. If anyone can give me a list or something. thnx
-Ricky
You're in the right place....Read, read, read.
Enjoy!
93240sxS13frontend
so what will i need
Craving4Boost
Car: 91 240sx fastback
just try and read..it realli does help...i kno u can come up with a good list soon enough...but if ur missing anything..post wut ur thinkin about buyin and we'll help u tell wut ur missing
93240sxS13frontend
What will i need to do anything with the 176K miles
Craving4Boost
it depends on wut power ur looking for...i have a 175k motor which im turboing in a week or two....im wannna aim for around 250hp and if ur doing the same then u should be fine without upgrading internals
d-ta
Car: S14
what you'll need
1. stfu2. search3. j/k, but you really should search
well first off you'll need a turbo hehe. next, a manifold and some oil lines.
that's a good start. then there's stuff like:
tuned ecu or safcinjectorsdownpipeintercooler + piping
start there. search more. kthx
93240sxS13frontend
Iam just trying to aim for around 225whp-250whp nothing major, what will you be doing to it, also wut kind of safc do you recommend
Craving4Boost
wel im turboing it of course unless u have a more specific question
Craving4Boost
i have an AFCII and iono if i recommend it becuz i havent realli used it i just installed it...alot of pplz in this forum use it and it seems to work well..wut kind of budget do u have
d-ta
Car: S14
93240sxS13frontend wrote:Iam just trying to aim for around 225whp-250whp nothing major, what will you be doing to it, also wut kind of safc do you recommend
your budget would be a good indication of what we can recommend you getting. also, maybe what you'd be doing with the car? (daily-drive, autox, road race, drift, etc.)
as for safc, i didn't think it mattered which one you got. both safc1 & 2 should do the job. then there's the hacked maf route you can readup on HERE
as for low to mid 200hp, perhaps a t25 or small-medium sized t3? some sr injectors, something to control those injectors like safc or tuned ecu, 3" dp & exhaust, simple log manifold, bov of some sort, fmic (not sure if an smic could achieve your goals. someone else care to chime in on this?).
93240sxS13frontend
Would the SR20DET turbo be fine (t25),would the manifold match or will it have a different ratio
d-ta
Car: S14
you could use a t25 off an sr, just make sure it's in good condition. it's been done before. as for the sr manifold, no. it does not line up with the ka. best bet is to get the ssautochrome one off ebay that's bottom-mount, flanged for t25/28's or jgs' weld-it-yourself log manifold.
hannibal
Car: Red Line to Glenmont
guys used to use SSA manifolds for the SR and simply cut off the SR exhaust flange and weld on a KA flange. So I think the spacing btw exhaust ports is the same, they just use different flanges. Now SSA makes KA manifolds, Ive heard some bad things about their quality. The JGS log manifold is an option if you want something more DIY.
I would suggest looking at larger turbos (like Z31 T3 or SR T28), but I'm sure the T25 can get you to your goals.
93240sxS13frontend
Also I heard about someone turboing thier KA with a Mitsu turbo of from a Eclipse, the turbo lookslike its the same as the SR20DET stock T25, Is anyone can take a look at this one, and figure out if it could work on my KA http://cgi.ebay.com/ebaymotors...hanx for your -Ricky
