texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Sat Sep 17, 2011 7:12 pm
1) The BG transmission flush ASAP (yesterday)
2) IF the transmission ,when HOT, perform well--shifts good,etc., then the unit is mechanically sound and problem is likely to be 'varnish/deposits' in the valve body which are inhibiting the movement of the precise sliding pistons.
3) It IS possible that a seal on one of the internal high pressure accumulators is stiff and leaking when cold, but sealing when hot--but that is low probability.
4) A decent transmission repair shop can do a 'pressure test' on the unit to check and see if the operating oil pressures are correct. If the high pressure is LOW, this indicates either worn pump, leaking accumulator seals, or stuck pressure control valve.
5) As stated---if the unit functions OK when HOT, then mechanics are good. BG flush should cur eit.
