i need help to get my car started
chino150240
Car: cars drifting racing drag
i have a 91 240 sx which i got from my freind because he couldnt get it out of the shop but instead of him puting it in a mechanic shop he took it to a body shop(shows how smart he is) but still i towed it to my house and its been sitting there for a while. until about 2 moths ago i had time to start and get it started but it doesnt crank it had the harnes for the coil and the distributo cut i replaced those and then i replaced 2 distributor but it still does not crank can anybody help me. it had gotten stolen when my freind owned it. can anybody help me :confused:
Silvia007
Car: 93 Nissan 240SX SE Fastback
Does not crank... check the battery, does the lights in the dash come on? Turn on the lights, is it dim? if there are no lights on the dash or lights are dim or no lights. bad battery. If after new battery or jump, it still don't crank, bad starter or bad wiring to the starter. That's about it for now, give us more info after you try that out.
Nismo_Freak
Car: 89 Nissan 240SX
Check for incorrectly grounded ground wiring.
Eastcoast Wildboy
That happened to me i had a ground wire from my fuel pump not grounded right.
chino150240
when i put a battery in there there is power through out the car. the only place that is not getting power is the spark plugs. but the coil has power too so i realy dont understand?:help
fiznat
Car: Grown up :(
is it turning over at all with the starter? worry about that first before you think about the spark: one step at at a time. If your starter isnt popping out or even doing anything at all, try turning the key to the "on" position and then shorting the + and - on the starter with a screwdriver. You'll get some sparks and the little gear should pop out and start whirring up. If it doesnt pop out, or does so really weakly, you're going to be needing a new starter.
Once you get it cranking and turning over, THEN worry about spark. It's probably your timing or a bad rotor or something (or your wiring), but figure out your starter first.
chino150240
the starter should be good because it trys to crank it turns over. ive noked it with a hammer and it did the same thing
fiznat
Car: Grown up :(
oh, you said in your first post that it wasnt cranking so I thought the starter wasnt turning it over...
Check the condition of your rotor + cap, wires, and plugs. If you're getting power at the coil then its most likely one of those things.
Eastcoast Wildboy
Plugs or wires like fiznat said. The caps should be fine from the sound it usually makes a funny noise when those go bad but still started the car.
lbrowne
one of the few distributors you installed maybe not lined up right? sounds like a timing problem if shes constantly trying to turn over but never catches.
be careful not to wash down your cylinder walls - which is probably too late since I think you tried many times to start this....and those before you.
Put the car at TDC, and get the distributor pointing to #1.
can you hear the fuel pump when you first turn the key but before you turn all the way? should hear a sort of buzzing sound...
if those wires were all cut when you got it, lord knows what was done to it.
