captn cookie »
https://forums.nicoclub.com/captn-cookie-u245442.html
Wed Dec 17, 2014 2:52 pm
Hello all,
I am new to the hard body world, and have just bought a 1996 2.4 4x4 5 speed king cab hard body. When I purchased it the guy said he screwed the timing up doing a tune up at night with his buddies. I should have known that something was up but I bought it with high hopes. When I towed it to my house I fixed the timing which was way off almost as he did it on purpose. It ran but was rough I thought ok maybe he fouled out the plugs. So I do a proper tune up when doing so the oil smelled like pure gas. When i completed the tune up and started the truck it was knocking very bad. I called the seller he said he knew that and thought a tune up would fix it. The truck only has 145k miles on it so I am asking should I rebuild the motor? My intentions to do so are if it is able to is have the block tanked (cleaned), trued, bored .002 or as I say 20 over, honed, and replace freeze plugs. With that have the crank grounded and polished if possible. I have seen some rebuild kits on rockauto that come with new pistons, front seal, rear seal, rings, bearings, oil pump, and all the gaskets. I plan on purchasing new connecting rods and water pump. A master mechanic friend of mine said that he check/rebuild the head if need be to square away a friendly debt. I would have the head inspected to see if it needed to be trued and cleaned as well. So I basically would have a new engine. My question is any suggestions to this? I have rebuilt several engines So i am always looking for a project. Looking forward to all input.
