please bolt the knock sensor back to that spot.. its not hard and its there for a reason
follow my write-up inside
took about 35 min tops
http://biggamehit.teammnr.com/
the knock-sensor when it goes bad will send your motor into fail safe mode. and will not clear if the sensor is faulty. also check the connections on the harness going to the sensor
