i need HELP!
mistahchan
I am doing a motor swap on my 90 240sx. i have went out and bought a 98 240sx and planning to put that motor in my car.I have everything including the wiring harnest from a 98 240sx what would i have to do to make it work on my 90 240sx.I am having trouble with the wireing so what should i do?
quiksilvia
Car: 95 s14 se
uh, first its a harness, second why are u going through the trouble, drive the 98
theronin
you bought a 98 so you could put it's motor in your car?
Nismo_Freak
Car: 89 Nissan 240SX
The 98 shares the a very similar wiring harness to the S15. Problem is your trying to wire S13 accessories to an S14 wiring harness. Locate the S13 KA --> S13 SR wiring diagram. Then compare it to the S14 KA --> S13 SR wiring diagram.
