doctorl »
https://forums.nicoclub.com/doctorl-u60475.html
Fri May 11, 2007 7:37 am
I just replaced mine (same year) with a Sony aftermarket unit from Crutchfield. When I removed the OEM unit (no power) it had two stickers on it indicating that it had been serviced twice before.
Carstereohelp.com will not service these any more -- too many coming back. If you want to stick with OEM they recommend replacing with a '95 or later unit which requires a harness adapter, but is otherwise no big deal. At least it gives you more options.
The Sony doesn't look like OEM, but overall the fit is pretty good and if you stay away from a headunit with a lot of silver on it it looks OK
