i need help!!!!!!!!!!
slide-or-die 240
Car: 1990 240 sx
i have had my 1990 240 for about 3 days and i have a problem.......it has a ka24...single cam....heres my problem....some times when i pull out it has no power in first and second....but once i hit 3rd it has power back.....and then other times....it will pull out and have tons of power through 1st and 2nd..3rd...4th..5tn...so someone please help......whats up wit the power loss sometimes....help!!!!!!!!!!!!!!!!!!!!
slide-or-die 240
Car: 1990 240 sx
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
you may have a clogged fuel filter
dRiLstar
!240RB! wrote:you may have a clogged fuel filter
what he said.. maybe not enough gas going thru so it's choking
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Clutch/slave cylinder/transmission/synchros for 1st and 2nd going out maybe? Check your timing, plugs, plug wires, distributor, etc. too. Do you get any grinding, or have a hard time shifting gears/getting trans to go into gear? What's this power loss like? Does it just go really slow and then when you hit third it's like you hit a 100 shot of NOS? When you're in 1st or 2nd and it's not responding/there is no power, does it feel like the more gas you give it the slower it responds?
slide-or-die 240
Car: 1990 240 sx
yea its like the more gas i give it the slower it goes.....and sometimes when i hit 3rd its like that ...other times its not but u can still feel a big power differance.......
slide-or-die 240
Car: 1990 240 sx
na i replaced the fuel filter
homeslicej2
That's weird. When my firebird did that it was the computer sensing detonation and retarding the timing. I'm not sure but I'd check the things I mentioned earlier. Also check/replace the coolant temp sensor (the ECU one, not the dash gauge one). This sounds like an electrical issue, but again I'm not sure and without being able to be there myself I am less sure. Are your battery cables and engine grounds good? Things like that would seem to effect every gear though. Weird. I don't know man.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Change the fuel filter.
homeslicej2
^Another good suggestion but again, wouldn't a clogged/dirty fuel filter affect acceleration in every gear?
rotorimp
Car: 02 Xterra, 60 IH Metro
Does it smell like burnt clutch? when your accelerting in 1st and 2nd does the car just seem to rev?
Tr0uble
Car: S13.5sx
slide-or-die 240 wrote:yea its like the more gas i give it the slower it goes.....and sometimes when i hit 3rd its like that ...other times its not but u can still feel a big power differance.......
Bad MAF sensor/sensor wires shorted out or loose piping somewhere between MAFS and throttlebody.
If intake piping including MAFS is all tight and has no leaks, then you have a short in the wires going to MAFS. Shifting/driving causes engine and wires to move your short lines somewhere in there. If you don't have a short then you have a loose ground. 99% chance it lines within this area.
dickie
Car: Killer Turtle
this issue is very common and can result from SEVERAL factors, all of which you can search for more info on.
check your grounds, spark plugs and wires, distributor rotor and cap, fuel injectors, air filter/mafs, fuel lines, fuel pump...
