i need help.
darkslide240
Car: 91 nissan 240sx
waz up yall,
i'm new 2 the site and i need advice. i have a 91 nissan 240sx, and i want 2 throw a turbo in it.but i run to high of a compression to put one on " this is what my teacher told me ". so i need help with this subject. or should i go no turbo?
thanks
darkslide
hazw8st
If you want to run a high hp turbo setup, you'll need to bump down the compression to at least 8.5:1 compression.
Chezedik
Car: 1991 Nissan 240sx
Your teacher is partially right. He is probably well versed in Carb'd Musclehead V8s. And in terms of Distributor controlled ignition and a carb, yes, compression is too high. But we live in a modern age (1991 modern?, well anyway)where timing control and fuel control are not independent from each other, which they cannot be. You can boost your Nissan, but you will be walking a fine line. This forum is filled with people who have done it, and in a few months (everything willing), it will have at least one more. So to induct you, the way we induct all noobs, I will point your attention to the top right corner, and you will notice a blinking red tab that says search. SO SEARCH!!!Welcome to NICO!
