PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Mon Feb 28, 2005 2:30 pm
SAFC= fuel injector control unit, allows you to run larger fuel injectors which allows you to run more boost, which allows more power=
JWT= Jim Wolf Tech, a re-flashed ECU, coming pre-tuned from Jim Wolf. Allows you to run larger injectors, like before, but if you wish to upgrade to another size, you have to send it out to get it re-flashed again.
MAF was mentioned before so i wont get into it
Standalone= self explanitory, Stands Alone fuel/ignition/boost system, allows the tuner complete control over the engine, downside is that it takes lots of time, patience, and skill to tune/install.
My opinion on the SR20- why go down in displacement? The KA seems to hold its own in power when turbod, and if you blow it, you can just go to a junkyard and get another one cheep, as opposed to waiting for another shipment of SR20s to come in and forking over another 2 and some-odd thousand dollars to get another one.As always, much of this information can be found by using the search function in this forum. ...and yes... Fu*k those VW Sh*tsDer 240sx ist shneller und starker als die Volkswagen (im a mechanical engineering/german major)
