MaxBolus »
https://forums.nicoclub.com/maxbolus-u65637.html
Mon Aug 15, 2011 5:54 am
Sounds like you only need to remove the bottom cushion, which is pretty easy.
If you look just under the front of each seat pad, you'll see a wire loop that goes into a little plastic lock. There should be a plastic D-ring sticking out, just pull on it and the wire loop should come out. Release both sides, and the bottom cushions should lift right out.
-m
