mod_mastaz »
https://forums.nicoclub.com/mod-mastaz-u62511.html
Sun Jun 29, 2008 10:43 pm
If it's running super rich, look at the coolant temp sensor. It sounds like it only runs good only when it's warmed up. Most nissans/japanese ECUs are reliant on the coolant temp sensor and if they are broken, it'll dump loads of fuel due to it being in limp mode then it'll run fine after it warms up. As for your idle issues, try to find the real problem and fix everything else before you mess with the SAFC. The SAFC is for tuning, not fixing ECU problems due to faulty sensors or other issues.
