i need help qx56
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
infqx56
Car: 2006 infiniti qx56
i have 2006 x56 i have this crazy problem my back door don't open only manuali my license plate bulb don't work only brake light and camera it good need help i use my power probe test light i don't have no battery power on that harness only groun need help asap thanks
marctronixx
cant understand all of what you are saying but i will attempt to decrypt your message and lend some starting points...
bulb out: both bulbs or just one? if both, replace. if just one, inspect the harness the bulb sits in. could be corroded, loose wiring.
any other lamps out? could be as fuse. if fuse is good and socket the lamps go in are clean, could be a break somewhere in the wiring . hard to tell about those things.
manual, there should be a manual/auto switch back there no? I am going by memory but i thought there was a manual/auto switch.
if no switch, could be faulty motor/defective. do you hear the motor run ? if not, motor could be disconnected from the harness, loose wiring, etc. check fuses.
infqx56
Both bulb i power teste they good it just to power and the motor don't make any nothing i check for power on the motor harness and i have 12v i need wire diagram front the back door harness to where ever it goes
marctronixx
Return to “Armada Forum / QX56 Forum / QX80 Forum”
