SunnyTk »
https://forums.nicoclub.com/sunnytk-u88278.html
Sun Aug 16, 2009 9:35 am
My car cannot move. Here is the situation
2 weeks ago, I noticed that the clutch would not grab at low rpms, then it just got worse and worse. Then last week while driving home from work, I couldn't change gears, the clutch pedal was still firm, and it had a bit of a rough feel to it. I could only shift by "rev matching". When I was rev matching, the clutch would not slip at all, like it was back to normal in a way. Then 2 days ago, the clutch pedal decided to work and I could change gear normally again, but when I'm in gear and let off the gas, the cars rpm would drop down to idle. And it slips at any rpm now.
I replaced the clutch slave cylinder, bled the clutch, there is no noises or leaks coming from the master or the slave.
Any help would be greatly appreciated
