I need help please.... Its about Valves ??????
89silvia13
Okay i been wondering this for a while... See i have a ka24e and i found valves on oandjperformane but the is no locks seats or springs, retainers for the sohc. But Everthing for dohc. Can i use the stuff from a Dohc????????
Warped161
Car: 90 s13 the never ending project
pretty sure the answer is no, unless your going to make some size changes to the head or the valves.
89silvia13
There all the same size arent they?
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
just give the manufacturer a call man and see if the lock angles and ribbing is the same for your single slammer....and no...locks varry depending on the maker...some use a 8degree angle..some 5..some even 10 degree..they may allso use 2 or even 3 ribbs (locking rings)..oem uses one...you will allso have to match spring retainers to the locks aswell..good luck
tycoonist
Car: 1990 240sx hatch
http://www.store.partsdinosaur.com/page125.html been planning on using 'em
http://www.importperformanceparts.net/i ... issan.html cant forget these
i need hydraulic lash adjusters
