I need help please 92 240sx accident
alex24
I have a 92 nissan 240sx and was hit in the front. I just wonder where I can get a radiator core support for the car? Is this a bolt on project? How much is the part? I am thinking of getting the whole radiator core support. Thanks [IMG][/IMG]
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Pics or fail. How can anyone poss. help you with that minimal info and no pics. At least tell us how bad the damage is. Is it the whole rad support, or just the top or bottom. Did you bend the frame. A lot more info is needed. And, unless you know how to weld, or fabricate. Done even attempt.
alex24
It is the top radiator core support only but is the whole apron affordable? How do I post pic here? Thanks
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
alex24 wrote:It is the top radiator core support only but is the whole apron affordable? How do I post pic here? Thanks
photobucket is your friend
Hijacker
Car: '92 240sx Convertible
'94 F-150
you'll have to host on another site and then bring it back here and use the [img] tags.
You can order the upper and lower supports brand new from Nissan or you can find one in a salvage yard. However, you will need to drill out the old spot welds and weld in the new one.
zerothread?id=330340
Look here for some good visuals on welding in the new support. I forget where in the thread he does it, but you should look at the whole thread anyways because it is super awesome
slidestyle69
Car: 92 s13
Just like HIJACKER said but prolly a good idea to have someone expereinced help you, i did it on my s14 but if i hadnt had friends that were good with body work then i dont think i could had got it as perfect as we did
alex24
I am in california. My car is a daily driver. I have someone who would pull it for me for $300. Should I go that route or is pucrchasing the whole core support make more sense? My core support damage looks like this guys car.
http://zilvia.net/f/tech-talk/....html
I would put the picture up in photo bucket now but I left my travel drive. I grab the wrong travel drive on the way out.
Here is a another pic what my car looks like.
zer...59169
thanks for all the help here.
blacksrjdm
If you can get it pulled for $300, then what is the issue here. If pulling it out will fix it, then why ask any further questions. Go get it pulled out and buy the body parts to fix the panels.
